Results 1 to 4 of 4
Thread: Good parts car?
    Default Good parts car?
    Hello, I've this is my first post here. But I've been lurking for a bit.
    Anyway, I've recently come upon the opportunity to buy a beat up 2002 v6 manual mustang for a couple hundred dollars. My immediate thought was using it for parts for my 1983 GT (4 speed manual, 302 HO, stock but kind of a POS as well.) Repairing the 2002 is not really an option and IMO wouldn't be worth it regardless.
    Mainly, I'm interested in the disk brakes and the manual transmission. The T-5 in the 2003 is very different from the usual swaps so I'm wondering if it's possible and what would be needed for it? I know swapping the whole rear end is not practical because it's 3 inches longer and the rear end ratio is not different but I'm willing to put up with that for 5 lug axles and disk brakes. I also know that I would need SN95 spindles and struts to make use of the front brakes. I know the usual answer is 'Not worth the effort, get something else' but seeing as I'm a broke-a$$ college student paying in immense amounts of effort instead of actual dollars is not a deal breaker.
    The long and short of it is: what parts can I use from a 2002 v6 manual mustang to improve my 1983, V8, SROD, rear drum brake, Mustang GT
    Barboursville, WV
    You typed 2003 v6 and then 2006 v6. I'm going to presume we're talking about a 2006 car, since you mentioned the t5 being different. I don't know anything about the brakes on the 2006 but I'm fairly certain the t5 on these cars is not an option for swapping into ours.
    Edit: Forgot to say welcome to the group!
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    Oops! it's a 2002 actually, so I got it wrong twice. Because of course I would.
    But thank you, I'm excited to be here!
    Barboursville, WV
    Oh, well in that case, snatch that thing up. You can use the t5 (it'll take a little work but it's worth it). I think the brakes can be used as well, but the spindles will have to be changed. The '02 spindles will bolt up and technically work, but the geometry is wrong. I do have a buddy who uses them and says they work fine, but the general consensus is that the 94-95 spindles are the ones you want.
    The rear end will be a 7.5 and although the splines match the 8.8, I'm pretty sure they are too long for the fox housing. The rear discs might work for a swap, though.
    I'm pretty rusty on the brake swaps. Several members on here could give you better info.
