I keep coming back to this idea and i don't really know why. I've planned this to the point where, at one time, I had a couple good 4 spd toploaders and a Lakewood bellhousing for bolting a toploader to sbf using a cable clutch setup.
But it dawned on me that the srod 4 spd, I believe, has the same bolt pattern as a tko. And a tko has the same pattern as a toploader. If that is correct, is it possible to use the srod bell with a toploader using the stock cable setup? I'm pretty sure guys were running toploaders in these early foxes back in the day. Was the swap really that simple?
