Results 1 to 4 of 4
    FEP User
    Aug 2013
    Lawrence Swamp. Amherst, MA
    Default ID Tranny, '85 LTD waggy
    Just brought an '85 LTD home.
    I have a 50 y/o rig (manual) and can name a few transmissions when seen. This is 35 y/o so I don't see many of them. It has a bad leak, looks like the frnt or back of the pump/. The prts guy came up w/more than 1. I thought at this point they were all C-5 but it showed a C-3 too?
    How do I tell what it is from below ona lift?
    Thank you,
    - -Da New Guy
    I heard a 4.2 head will pep it up.
    Any yeas? more 'dont bother's?
    Chad
    Seeking: fox station wagon int/ext trim (esp LTD/Marquis)
    Retire/restore ol Bronk to daughter
    chrlsful@aol.com
    FEP User
    Aug 2013
    Default step 2, remove, repair, replace C4
    Quote Originally Posted by chrlsful View Post
    ...How do I tell what it is from below ona lift?...
    Got the C5 parts (2 seals, frnt pump gasket, pan gasket)
    Pan gasket told the story, lucky - the pump gasket fits both - - I gota C4. Good.
    Single pump gasket fixed it, screen was clean frm OP's g a l l o n s of atf pour in.
    Took off Y pipe stubs for easier instal. Topped off w/ 10 qts dexteron. No more leak.
    Still starts/idles/runs fine. A lill rough till upta temp (1st 3 min). Never hada CFI B4. What sensor, vac line, etc might it be?
    On to exhaust. Need manifold to tail pipe. Any idea if there's a cat-less Y for this. I imagine it takes 2 (the OP seems to have cut them off for selling (two 5 inch stubs all thats left) and pretty expensive~
    Chad
    chrlsful@aol.com
    Grand Rapids, MI
    I'm pretty sure the C4 and C5 use the same pan gasket. Unless somebody installed a C4 down the road your car should have a C5.
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
    FEP User
    Aug 2013
    Thanks for the post KV.
    interesting.
    The gasket that fit the pan hada jog, the C5 was square.
    Chad
    chrlsful@aol.com
