Results 1 to 7 of 7
    Default 82 T-Top Molding trim - Above Sail panel
    Hey guys, I'm looking for a short piece of molding that sits above the sail panel on my 82 Capri T-Top
    Any ideas on where I could get one?
    Thought I had one. Only have the passenger side.
    `82 Mercury Capri 5.0 4.speed / not RS
    `86 Mercury Capri
    On my t-top parts it looks like that is a regular hardtop piece that was shortened with a cap. You may be able to just reuse your cap piece and source a trim picec and cut it down to length.
    ^^^^^^^^^^^^^^^^^^^^^^^^ What he said above!
    I would have to double check my Ford disk to see if there is a specific part numbers for those pieces, but even then finding one may prove difficult. Easiest option is to just cut down a standard hardtop trim piece and reuse your cap if you have it. Otherwise you can probably fill the end of the trim piece with 2K urethane adhesive/sealer and then just sand smooth and paint. That is my plan on my 82 GT that is missing the same side.
    FEP Senior Member Realmongo's Avatar
    Sep 2005
    Western Mass
    I had to find a replacement for my passenger side.
    Finally found a wrecking yard with a car in it.
    Not really sure what holds it to the car though now that I have one to replace the missing part.
    John
    2017 Convertible 6-Speed
    1984 GT 5.0 T-Roof
    1965 Coupe 4-Speed
    1964-1/2 Coupe C4-Auto
    MCA National Certified Judge 1964-1966 and 1979-1993
    Quote Originally Posted by Realmongo View Post
    There are small clips that hold the molding onto the pinch weld at the roof line. The are very thin and often come off with the molding and are hard to see due to the butyl sealant. They often break too due to age, Unfortunately I am not aware of any replacements available at this point in time. Good Luck!
    Sep 2005
    Western Mass
    Thanks, I will look into it!
    John
    1984 GT 5.0 T-Roof
    1965 Coupe 4-Speed
