Results 1 to 9 of 9
    Default Wipers won't shut off
    83 gt wipers won't shut off or change speeds can't seem to find any place that sells a new switch
    You never heard of Goggle??????????????
    https://www.google.com/search?q=83+mustang+wiper+switch
    As mentioned above, ebay is the most likely place to find a new or used switch.
    Wow yeah never heard of it but I Googled d bag and your name came right up seems it works pretty good . Was just trying to see if anyone else had this issue and if it was the switch or someone had a source for new ones besides ebay
    once had my wipers coming on when i turned on the headlights
    turned out to be a bad ground connector on the radiator support
    was backfeeding somehow. electric can be strange.
    found the fault by luck when probing the headlight circuit
    Yep, that is what happened to me. Unplugged the wiper motor until I found the problem.
    It was a bad ground from when I repainted the engine compartment.
    http://myzephyrs.com
    Thanks I'll start checking grounds before replacing parts
    Oct 2017
    south-central WY
    If you have interval wipers, you may want to read this:
    http://vb.foureyedpride.com/showthre...nterchangeably
    Ok so finally got around to trouble shooting this and the interval governor has already been bypassed, so I unplugged the harness checking for voltage as another thread said to weird thing is I have power on the red wire on the side that goes to the motor and its unplugged on both ends any ideas
