    FEP Senior Member fascat's Avatar
    Greensburg, PA
    Default Metal Intrior Trim removal above doors and windshield
    I’m looking to remove the metal interior trim pieces above each door and above the windshield on my 1986 Capri. Are the clips supposed to come out with the trim pieces? Anyone have any tips on removing the metal trim pieces without damaging them? I appreciate any suggestions.
    Whitestone, NY
    You kinda grab them with your hands and pull them off. Use two hands and grab them (work your fingers between headliner and trrim) and yank it down starting from one end to another. The clips stay with the trim.
    To expand on what 87gtVIC stated above, I have found that if you sit in the seat and place your legs out the door. Grab the trim as mentioned above working your fingers behind the edge at the headliner as much as possible and then I pull with both hands at the same time and roll my wrists in a downward motion. That seems to pop the trim off the quickest and easiest for me. As stated the metal clips stay with the trim, but they do slide side to side and can fall out if you aren't careful. When you go to reinstall, there are small triangles or arrows stamped into the backside of the trim on the edge to help you locate the clips. Center the clip on that triangle/arrow and reinstall. I usually push them in my hand and then give them a good smack over each clip with a side of my hand with a clinch fist. Not trying to damage them, but sometimes you do not to get a bit physical for them to seat properly. Good luck!
    Great info here
    Greensburg, PA
    Thanks for the tips guys. I really appreciate it. I'm looking to refresh the interior on my car this winter and wasn't sure how those trim pieces come off. Like massacre said, great info. Much appreciated.
