Results 1 to 3 of 3
    Default Ford CM-4915 injectors.
    Came accross some CM-4915 injectors lying around in my garage. Does anyone know if these will fit my 1989 5.0L ?
    It appears they fit 99-04 F150 with the 5.4 V8 or at least originally. They will fit your 1989 5.0, but are higher flow rate than the original 19lb at 42lbs I believe. That is if they are the green top injectors. So unless you have increased the HP of the engine, they are probably too big.
    What would happen if I use them ?
    Save me from rebuilding the ones I already have.
