    Default 86 LTD Tail Lights
    Just brought home an 86 LTD that we are going to make a drag car and the drivers side tail light is busted. anyone know where to get a used one? all i can find are passenger side ones of course. also, does anyone know if mustang tail light housing can be fitted? thanks in advanced.
    Grand Rapids, MI
    A similar year Marquis will also fit, but it will look different than the LTD light. A Mustang light will not fit at all. You can try ebay or car-part.com. Just make sure you are buying an actual LTD tail light and not the much more common LTD Crown Victoria full size car tail light. Car-part does not distinguish between the two very well. Sometimes people mistakenly refer to our cars as the LTD II as well. Thanks Ford.
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
    Thanks for the reply! might have found one car-part.com. is the front end body and engine bay wise the same as a fox body?
    Grand Rapids, MI
    Well technically the LTD is a fox body car. The front end sheet metal is significantly different from a Mustang although I have seen Mustang front ends grafted onto the front of the LTD. Under the hood should be very similar/same to a Mustang.
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '97 Thunderbird
    '85 Ford LTD Squire
    exactly what I needed to hear! Got the front tube kit, k member and trans cross member.
