Single wire alternator
84 Ltd lx t5 347,
The 347 came with a single wire alternator setup. Alternator works fine, and I have an after market voltage gauge. since I bypassed the factory wiring harness the charging light stays on. Is there a way to hook up the warning light, so that it functions correctly? Is there a way to shut it off when the engine is running?
Thank you, it might fix the issue.
- You may not post replies
- You may not edit your posts
Forum Rules
