I am going to have to build a new wire loom for the engine connections. Can anyone tell me what gauge the wire is? I would guess 18 gauge??
Different circuits require different gauge wires.
I have one of those big paper wiring diagrams usually found on ebay. Those manuals list the gauge of every wire in the car.
What year/car?
Fill out your user info and put in your sig. Or, specify in the post (imho, the best way).
Do you mean Wiring Harness?
Note, you want the exact year, for your car:
Ebay search: ford wiring diagram
Example: 83 ford wiring diagram
Good Luck.
I took a better look at the engine harness and they look like 14 gauge with a couple of 12 gauge wires.. I might build a new one with all 12 gauge.. Thanks.
