Cant figure out how to upload pictures. Here is the description, and the Facebook marketplace link.
1985 Mercury Capri RS. This was the last year for the carburetor cars, and does not have a third brake light. Original RS car, in this trim package. According to the Marti report, this is one of 150 that were produced with this trim package. Has a 351 windsor with trick flow heads (ported and polished,) Edlebrock intake (match ported and polished,) Holley Speed Demaon carb, 980 cfm. 4" stroke crankshaft, .30 over block, for 408 cubic inches. The motor was professionally done by Ford Performance Solutions in Anaheim, CA. Serpentine belt drive, high flow water pump, etc. Electric fan, under drive Pullies, Cooks custom long tube headers, and a 3" Flowmaster exhaust with X-pipe. Richmond 6 speed transmission (5 regular gears plus an overdrive gear.) 8.8" rear with 4:30 gears. Auburn positrac. Total drivetrain has 5k miles as seen on speedo, Body has 85k miles. Car is nitrous. Solid camshaft, 1.7 roller rockers, and all documentation for the car, except the cam card .560" lift, with 280 degrees of duration. Tubular front K member, and A arms, solid motor mounts. Lakewood bell housing, Ram clutch and pressure plate (3 finger,) also new.
Have the original ten hole wheels, with cougar center caps. Interior is clean, but not pristine. Same goes for the body. Cowl hood is pinned, with no hinges. Fuel sump, holly blue pump, stainless lines, Subframe connectors, professional roll cage, south side traction bars. Carpet is a reproduction.
https://m.facebook.com/marketplace/i...1475208865390/
