New User
1986 clutch weird noise
*VIDEO LINK BELOW*
when I push the clutch in or release it, I get the squeaking noise that can be heard in the video, you may have to turn your volume up a bit to hear it clearly. I thought it was the clutch cable at first so I replaced it but I still hear it. I haven’t owned this car more than 4 months so I’m not super familiar with it yet.
the clutch works fine though, has no problem going into any gear.
https://youtube.com/shorts/M_jy0eYIrpQ?feature=share
Had a similar issue on my 86. Could be several things. Turned out in my case it was the lack of grease on the input shaft causing the throw out bearing to squeak. A very light coat of grease on the input shaft solved it. Unfortunately the gearbox has to come out to do that. Other than the annoying noise, clutch worked fine.
- You may not post replies
- You may not edit your posts
Forum Rules
