Results 1 to 3 of 3
    Nov 2003
    Ohio City, OH
    Default Brand New Trick Flow 11R170 heads and FTI Custom cam
    I have a brand new set of Trick Flow 11R170 Twisted Wedge heads and Custom FTI hyd roller cam. The heads have the 53cc chambers. The head were bought and assembled by Ed Curtis at FTI and he used his own Extreme duty PAC racing springs, Tool Steel retainers/keepers and seals. They also have 5/16" guide plates and 7/16" ARP rocker studs. The cam is a hyd roller designed for a carbed 302 with stock shortblock pistons. The power range is 2200-6300+. The new 11R170 valve angles allow a lot more cam than other heads out there. That allows the .605" lift on the intake side. The cam duration and lift is the most you can run with stock pistons. It will also work fine with aftermarket pistons with eyebrows. Every thing is brand new still in the boxs. My cost was over $3000, but I will take the first $2000 plus shipping for everything. I am set up for Paypal too. aarongardner@frontier.com OHio City, OH
    PM Sent
    Nov 2003
    Ohio City, OH
    The 11R170 heads and cam have been sold!
