Results 1 to 7 of 7
    Default Dual snorkel air cleaner parts
    Digging up the parts in my 6 to 8 conversion. Got my dual snorkel air cleaner. Looking for the pieces that go into the side of the inner fenders. Found the rubber extensions from the air cleaner from Classic.
    Any tips ?
    Barboursville, WV
    Unless someone started making them in the last couple yrs, I believe you'll need to source used ones. They're not too difficult to find. Post a wanted ad here and you will probably find what you need.
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    As stated used is the only option as of right now for the fender tubes. Both sides are the same, so that makes it easier to source them. Essentially any model with the fender tubes will work for your air cleaner. Good luck!
    1985 GT 5.0 CFI / AOD
    All Original
    How do they affix to the inner fender ? Are there pieces attached to the inner fender ?
    LMR's Installation video: https://youtu.be/gbWe8NB9rYk?t=38
    All Original
    Thanks for the video. I’m more concerned about the inner fender pieces. That are not available as mentioned earlier.
