Results 1 to 2 of 2
    Default 1986 tail lights not working but everything else does
    I got pulled a couple weeks ago because my cars tail lights aren’t working. The brake lights, turn signals, headlights, high beams, and gage cluster lights all work fine though. As I went to park my car, I turned my lights off and my girlfriend said she saw the tail lights flicker, so I went and jiggled the light switch and the lights flickered again. So I ordered a new light switch, installed it and the lights still don’t work.
    I unplugged the new switch and looked at the wires and connectors for anything out of place but couldn’t find anything. What do you guys think? Fuse? I’m not good with wiring but clearly the switch wasn’t the issue and now I’m left not knowing what to do, especially since the connectors look okay.
    I would check the wiring between the switch and the taillights for corrosion/damage or a loose connection?
