Results 1 to 8 of 8
    Default Need some CARB guru's to jump in here...
    1986 stock bottom end 302, Trick Flow heads and cam, Edel RPM Air Gap Intake. Installed an Edel #1806 650 CFM Carb the way it came out of the box... and my A/F is 22.4 !! It came with (and currently has) a .095 Primary jet, .098 Secondary jet, and a .068" x .047" Primary rod... what size jets/rods would you guys recommend to richen it up?
    '86 Capri 5.0, black with charcoal interior, 5 spd, fully restored, mildly modded.
    '86 Capri 5.0, white with black interior, C4, rotisserie restored, heavily modded.
    22.4:1 when/where? Like, whereabouts are you getting that reading?
    That kinda number is no pig, and is actually leaner than nobody's business, and needs no leaning out, but enriching... so color me confused...
    Yeah sorry, mind is scrambled... thinking backwards. Where would I start to richen this up?
    Oct 2017
    south-central WY
    It would really help if we knew what rpm and throttle position you were driving when you got the 22.4 afr reading. Was it at idle? 3000 rpm and half throttle going uphill?
    Feb 2009
    Jackson, NJ 08527
    If it was really 22.4:1, it either would not run at all (idle) or would have blown up, if more than a couple seconds
    under load.
    Oct 2017
    south-central WY
    under load.
    Quite right, we need more data, 22.4 isn't realistic.
    FEP Member jsfrv6's Avatar
    Dec 2012
    Picayune, Mississippi 39466
    Sound like you have an exhaust leak letting tramp air in the system...
    Scott
    Picayune,MS 39466
    Torch Red 2004 Mach 1 Mustang
    Silver 85 GT
    Previous set up...
    306, Lunati flat tappet, Eddy Performer Heads, RPM intake, Holley 650DP, Shorty Headers, Flowmasters, 3.73, T5. 12.92 @109
    Current set up,,,
    408w, Internally balanced Scat rotating assy, Comp Hyd roller, Brodix heads, eddy air gap RPM intake, PowerjectionIII EFI, Longtube 1-3/4 headers, Flowmasters, 3.55 Cobra 31 spline diff w/Moser axles, TKO 600 5spd, Mcleod dual disc street clutch... ET... Traction Limited 11.93 @120mph
    ... or... misfiring, including RICH misfiring, will indicate lean on an AFR gauge (there's FAR MORE air goes out of the exhaust than fuel with misfires). Oxygen sensors and an AFR gauge is only a tool. Always best to judge how the vehicle is functioning, and such as looking at the condition of spark plugs, instead of chasing any certain AFR numbers... because chase your tail indeed is what will be if solely relying on looking at an AFR gauge.
