Results 1 to 4 of 4
    Cool Trans crossmember
    What i remember is you can use the sway bars from 94 - 95 on a fox body but i dont
    Remember if you can use a trans crossmember from a 94 - 95 prob. Not
    But can you?
    The transmission crossmembers are 82-93 and 94-98.
    The Sn95 front sway bar can be made to work on the Fox, but it is wider and requires either using SN95 lower control arms or drilling new holes in your Fox length control arms for the sway bar end links to be installed at the proper angle.
    Yea found my info its the rear bar they say fits
    I would think drilling the control arms would change the geometry of the suspension when using a wider bar.
    Theodore J. Garbera, 1985 Mercury Capri RS
