Results 1 to 4 of 4
    Default 1985 Mustang GT Project
    Hey all,
    Since I've purchased a 66k mile 85 GT, I'm going to sell my project 85. I bought the car for $2k and have purchased a lot of parts (almost $3,800) for a total of $5,781. I'll get this back to a roller but it will come with the engine, T-5 trans, and a replacement center console. I replaced the front frame rails and fixed the strut towers. The passenger floor pan needs patched and there are 2 small areas to fix in the back seat area. I also have 2 rear fender patch panels that come with it.
    I'd like to get $4k for it. If you want to see it, I will schedule a facetime (iPhone users) or we can do a FB messenger live call.
    Located in Moores Hill, IN 47032.
    Car Car, replacement pass side door, replacement hatch 2000
    Facebook Market Place A Pillar Plastics 40
    Facebook Market Place Engine Bay Wiring Harness 100
    LMR Frame Rail 279
    LMR Frame Rail 284
    Facebook Market Place Center Console, rear quarter panel patch panels 225
    LMR Springs, caster / camber plates, rubber, sway bar links, strut mount, strut bolts 837
    CJ Pony Parts Shocks and Struts 216
    Market Place HVAC Control 115
    Rigid Axle Ring and Pinion 257
    Rigid Axle Diff Clutch Kit 153
    LMR 7.5 bearing kit, headlight dividers, sway bar mounts, sway bar bushings. 244
    National Parts Depot 7.5 diff spring 27
    Rigid Axle Spider gears 115
    Facebook Market Place 7.5 diff carrier 75
    Market Place Driver Side Door 100
    LMR Steering rack, shaft, bump steer kit, rack bushings 714
    Total Spent $5781
    Name:  DS Suspension.jpg
    Name:  Steering Rack Installed 1.jpg
    Name:  DS Suspension 2.jpg
    Name:  Bay Complete Paint 2.jpg
    Total Spent $ 5,781.00
    Any pics of the replacement car?
    82 Mercury Capri - 11.99 @ 112, AFR headed Mountaineer motor
    86 Mustang LX Coupe - the original Coyote swap 4-eye. Gone but not forgotten!
