Results 1 to 13 of 13
    Default Unusual Spark Plug Fouling
    When checking on the old spark plugs removed from engine (1983 5.0) I discovered that spark plugs 1,2,5,6 are really sooty while 3,4,7,8 are a little too clean. Looked around internet and couldn't find much. Have any of yall ran into this or have a possible explination?
    The engine is mostly stock except from carburetor (holley, 80457-13 written on choke) up and no egr spacer and valve.
    Spark plugs 2(sooty) and 7(clean) shown
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Barboursville, WV
    The sooty plugs could just be due to ignition problems, such as bad plug wires.
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    Mar 2003
    Lowell, Oregon
    That would be my guess, too. Also make SURE the wires are FULLY seated on plug and dizzy.
    Worst case - do a compression test if wires are not the issue. If those cylinders are not sealing as well (valves/rings) then it may not be fully burning either.
    Along with the sparkplugs i changed them with new wires. I'll update this thread when I inspect the spark plugs again. I'm still baffled and the stark contrast and the particular set of cylinders afected.
    May 2016
    Lake City Pa 16423
    sounds like intake gasket leaks or base gasket under carb. The front plugs rich, rear plugs lean. If you have the stock carb, could be idle jets need adjusted.
    This is amazing thanks for sharing this post I have become a fan of your post now. This post is so interesting and informative.
    Is the intake dual plane?
    The intake is the stock aluminum dual plane. I have checked for manifold and carb base leaks before and found none.
    I assume the planes don't map to your groups of foul plugs?
    That is true. The difference is front half back half not left bank right bank.
    wonder if there's a fuel atomization problem with the carb spoiling the party
    I would make sure everything is completely clean.
    Also that there isn't a vacuum leak where the carb seals to the intake.
    Introduce a leak and all bets are off.
    Seems to me I fought this once because of a brake booster. The stupid thing still worked OK, but it leaked enough to cause problems.
    Hi there, I have similar issue, front 4 plugs clean rear 4 sooty! Did you resolve your problem and how ? Thanks Bob
    You say you have the stock factory 5.0 intake manifold.
    You mention that you’re not using the EGR cast iron carb spacer.
    Unless you’re using a special block off plate, there can be an exhaust leak at the carb base.
    The factory manifold has a weird design that uses the EGR spacer to completely seal the intake system.
    This happened to me when I tried to remove it and use a standard holly carb spacer.
    This could be a source of your problem.
    I would also hook a vacuum gauge up and see what the engine is doing.
    The Vacuum readings will help eliminate other problems such as bad valves etc.
    As previously stated, you might “just” need a mixture adjustment, an a vacuum gauge is the best tool for the job,
    Scott
    84 GT 5.0L, T5, 8.8T-Lock, 5lug with 93 Cobra Brakes,
    MM RCL's,CC plates, Koni Reds, 17" Tri-Stars...CoilOvers next.
