I’m looking for some advice from people that have ran into this issue before. I have installed a steering rack from a low mile 2003 GT and Maximum Motorsports hybrid steering shaft in my 85 GT. The install was fairly painless, however the shaft is only 1/16 of an inch from my MAC unequal length headers. I tried adjusting steering column over by undoing the bolts under the dash and prying, but that only marginally helped. My motor mounts appear to be in good physical condition, even though they are 20+ years old.
Based on this I believe I have two remaining options.
1) Dimple the header - I’m not opposed to doing this, however it’s rubbing on the weld of the header where the four tubes consolidate to one. I’m concerned either I won’t be able to make enough room or I’ll crack the weld. See picture.
2) Move the motor - Apparently there is some play with how the motor sits in the k member? I have read that I can possibly shift the motor to the passenger side to gain the clearance needed. I don’t have an engine hoist, but I could likely rent one. How do you about doing this? Undoing k member bolts, raising the motor and then pushing it over as you let it down?
Which option would you try or am I missing another option?
