Results 1 to 14 of 14
    Default DEATH TO WHEEL HOP! Help me eliminate it!
    1980 Mustang base model 2.3L, now has small block V8, Tremec 5 speed, 3:73 Ford 9 inch rear end with no quad shocks of course, 5 lug upgrade, 4 wheel disc brakes and sub frame connectors. Just now starting the suspension mods - no major changes yet. So obviously, we have mega-big wheel hop.
    New upper and lower rear control arms and torque box reinforcements already on the way. What else?
    I'm debating whether to go with lowering springs and Koni shocks, or maybe add coilovers (love the adjustability but not sure about pressure on the shock towers). But the wheel hop must die! What has worked best for you guys? Thanks for your thoughts.
    I run Pro3i lowers with poly bushings, stock HD Ford uppers with new rubber bushings on diff side, Koni Blues and stock quad shocks and MM pinion snubber. Zero issues with wheel hop.
    Jeremiah
    1986 Mustang GT 5spd, 3.27's
    Put quad shocks on the car. Ford did so for a good reason.
    Jack Hidley
    Barboursville, WV
    I always thought Ford did it as a band-aid to mask the real problem, which was flimsy control arms and torque boxes.
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    In 1978, when the Fox chassis first came out, both ends of the RLCAs had round bushings in them. The put slapper bars (mini transient torque arms) on as a fix to control the wheel hop.
    Around 1982, to improve the ride quality, they changed the front bushing design to the oval one. This allows the entire rear suspension, wheels and tires to be able to move rearwards, when the rear tires hit a bump. This improves ride quality. It would have resulted in a large increase in wheel hop, because the axle housing is now free to rotate around the axle centerline more easily due to the increased compliance of the bushings in this direction. To fix the problem, Ford added dampers which are oriented so that when the axle housing tries to rotate around the axle centerline, the dampers get extended and compressed as much as possible. This is why they are oriented horizontally.
    Unless I absolutely had to, I would leave the quad shocks on the car. With any suspension design that can have wheel hop, they can only help improve things.
    Jack Hidley
    What control arms are you currently using. Good chance they may be contributing to your wheel hop issue.
    Nov 2004
    Chas. SC
    On the '84 I left the 4 shock suspension alone and put a pair of square MAC LCAs on. Never a hop to be felt.
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    Me too. But that doesn't mean they won't work. Maybe Jack is onto something.
    It's a base model 4 cylinder.
    Stock from the original 7.5 inch rear end. New control arms are already on the way. You're right... surely they've got to help.
    Sep 2014
    Freeport NY
    on my 84 5.0 LX vert, I swaped the 7.5 rear for a rebuilt, 8.8, put in new Gabriel Quads, and replaced the lower control arms with Maximum Motorsports control arms and I have never felt a wheel hop since.
    Mar 2013
    Where the Navy sends me...
    I've never experienced wheel hop in my '89 GT, including during the 7 years or so that I owned it with a stock rear suspension. The quads shocks work as intended.
    What about wheel hop on heavy braking? I’ve experienced wheel hop under hard braking(100-60mph). MM MAX grip box 85 fox. ST40 cobra brakes. I was told this can break trans tailshafts and it was really scary(lol).
    "40 year old beercan on wheels with too much motor" erratic50
    If it happens during braking, then it is brake hop. You need to have an adjustable proportioning valve in the car and use it to reduce the amount of rear brake bias, until the brake hop stops. If you use a rear pad in the car with a lot of bite, that will make the car more likely to do it. It will break parts in the car, so you must avoid it at all costs.
    If you are downshifting from high speeds, that creates brake torque in the rear axles, which can also cause it. Make sure to match rpms well on the downshifts to stop it from happening.
    Jack Hidley
