Results 1 to 2 of 2
    Default 84 Mustang Top end Build
    Hey all. I am thinking of the following build and wonder what you all think?
    - Trick Flow 170 heads
    - 1.6 Roller rockers
    - B Cam
    - Linkbar roller lifters
    - Edelbrock 1406 Carb
    - Edelbrock Performer intake
    A few questions - PTV an issue with this head, cam and my 84 stock pistons in general?
    Thanks alot
    Jul 2010
    Houston (Clear Lake), Texas
    That motor has cast aluminum pistons which have 4 valve reliefs. If the valves are larger...which they probably are in those heads...you will probably run into PTV issues and the valve reliefs will need to be fly cut larger. This will also depend on cam timing events.
    HAD
    HAVE
