Results 1 to 6 of 6
    Default Door bottom rust
    Anyone seen corrosion like this here? Up close it looks like a bad clad weld, just to the left of the nut. It may be a low spot that doesn't drain well and it's only on the driver door.
    Nov 2004
    Chas. SC
    My '84 has the same issue.
    My unsupported theory is that the drivers window is down with an arm resting on the "Dew wipes" much more the passenger side. This will deform the weather strip just enough to let rainwater in. All you need is one drain hole plugged and water sits and starts the rust process.
    Just a supposition...
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    I live in West Virginia. I've never seen a door bottom that clean.
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    Good to know and that makes sense. When I repair it I may leave a drain hole there.
    A lot of the time we complain about the wet winters out here in Washington but no salt is a blessing.
    New User Four Eyed Fox's Avatar
    Mar 2013
    South Eastern Pa. Bringing up the rear of The rat race...
    Is there door skins available? or repair panels?
