Results 1 to 12 of 12
    FEP Senior Member ddx77's Avatar
    Jul 2011
    Fort Lauderdale, FL
    Default Where is the best place to buy floor pans
    Anyone have any suggestions on good quality floor pans and where to buy? Really just need rears.
    I was stripping down the rest of my interior and found some soft spots in the rear floor pan under the insulation.
    Wasn't a pleasant surprise but could have been worse, not the end of the world.
    Name:  gt floor s.jpg
    NPD and LMR are probably your best options. I don't believe anyone sells just the rear pans. Also the areas you show in the picture that have the open rust holes under the seats are technically not the floor pans, but the hatch/trunk floor area and I believe only the 87-93 style stamping is available. Best option under the seats is to either get a patch panel from a donor vehicle or just patch in new metal and finish as needed. Good Luck!
    Patched mine were worse
    did repair after it provided an oppertunity
    rust out made easy access for a breaker bar on the ps rear lower control arm front nut
    cut out rusty tin, vac area
    treat surface rust with hammer paint or similar rust inhibitor.
    steel or aluminum sheet or plates work
    screw, rivet, or weld. Be aware of what is on the other side of floor pan. Fuel lines, brake lines.
    Jul 2011
    Fort Lauderdale, FL
    Will do, thanks for the tips!
    https://www.c2cfabrication.com/colle...d+mustang+1985
    I have no experience with this vendor but they have rear floor pans.
    85 GT - owned since 87
    Jul 2011
    Fort Lauderdale, FL
    Default Floor pan patch
    So this is where I am at.
    I had these patches tacked into my rear floor pan (the under rear seat area). The welder couldn't go all the way around the floor pan material was just too thin he said. He also suggested for me to use windshield adhesive to fill in the seams, I was just going to use 3m seam sealer on top and below.
    Any suggestions, I don't want to mickey mouse it.
    I am going to paint the pans top side and under side, then sound shield over.
    Drew
    Repair looks fine from here. Now to make it pretty and sort of disguise it as a factory patch.
    Factory uses seam sealer on many areas of panel structure where two panels meet.
    Fixed rusted door bottom seams and hatch seam areas with it. Flexible enough to hold up well.
    Look is similar to factory seams and is paint-able.
    Popsicle or kraft sticks work fine as smoothing tools or a mix stick for plastic filler.
    Am happy with using black wet/dry plastic roof cement in rear wheel wells. Look is the same, takes months to firm up.
    Have recently repaired rust outs. Cut out rust, formed and riveted gutter mesh on backside over holes, then bondo glass. Regular bondo does not hold up for hole patching because is affected by water especially from back side.
    Repaired the Ranger's cab corners that way. Rock hard looks fine. Passes a 'kick' test no denting. If it fails, will buy metal repair sections.
    Sealed the back side of repairs with more glass or roof cement. Overall less work and cost than larger new metal pieces.
    Pretty much got the rivet idea for metal work from seeing how C&C did T-roof structure mods and when replacing outside door handles.
    HF pneumatic 1/4" rivet gun has paid for itself. Does smaller sizes too but have a 2nd gun set up for those. Handy and fast one handed tools.
    Convertible cars also have under chassis bracing installed using rivets. Ford included a bag of 1/4" steel ones with the chassis stiffening kit.
    Riveted my patch over the sub frame channel so as to access the rear lower control arm front bolt if needed again in the future.
    If using seam sealer, check for fresh tubes at store. Auto chains may not sell tubes fast enough and it hardens in tube.
    Black hammer paint works great for repainting very durable. Has texture but lasts much longer than regular rustoleum paint on chassis.
    Jul 2011
    Fort Lauderdale, FL
    Thank you! Yes going to use seam sealer for sure. Thanks again for the reply and the tips!
    Barboursville, WV
    Looks good!
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    Jul 2011
    Fort Lauderdale, FL
    Thank you, repairing the pans, although not a huge deal, was a huge hurdle to get over. Now hopefully the rest goes a little easier.
    Looks good!
