Results 1 to 4 of 4
    Default help identifying three wires
    Looking of some help in identifying these wires on my 86 LX. I did a harness tuck and forgot where the three go. They are two sets of the on either side in the front wiring harness near the headlights. The red has a black tracer, the black has a gray tracer, and last one is black.
    Dec 2002
    New Boston, MI
    The one with the eyelet is a ground. Probably goes to the radiator support.
    No idea on the other 2.
    The round eyelet as mentioned goes to the green screw on the corner of the radiator support just behind the headlights. The red with black tracer is for the LH headlight low beam and the Black with the white tracer should be the actual ground for the LH low beam headlight.
    Now I noticed that they pulled out of the plastic light socket.
    Thank you.
