Results 1 to 7 of 7
    Default New brushes for weak window motor?
    Lots of posts on replacing gears/plastic dowels. I've done all of that along with cleaning/lubing regulator(s). The issue is both door motors struggle to get the glass back up... barely makes it up to the top. New motor choices are not encouraging and I'd really like to keep my original hi-torque motors.
    Has anyone changed brushes in a weak motor successfully? Did it bring back the strength?
    I haven't opened the motors up yet, but suspect the brushes are worn down.
    Suggestions welcome!
    86 LX Coupe
    I just swapped out the rear window motor on my 86 Bronco due to the OEM crapping out. I used Dorman Part # 742-251 for the window motor. I have to say I am happy with the overall power and ability. Works very much like new. It's early, so I could be unhappy at a later date, but for the time being, I will continue to use them. I actually bought both sides 742-251 and 742-250 since online couldn't determine if the rear window used a left or right side motor. I will buy a replacement and use the two motors to replace the motors in my 86 Road Racer. The current motors work, but as you stated then struggle just a bit. I figure if it can raise the full size rear window with new weatherstripping all around it should do just fine with a Mustang side glass. I purchased mine through Amazon for @ $26 a side so can't beat that. Good Luck! Oh and the motors come with multiple wiring options, so it will connect to your existing pigtail with no issues.
    May 2016
    Lake City Pa 16423
    If a motor needs new brushes, it usually won't run at all. Replacing the brushes won't make it work any faster or stronger.
    Ford sold rebuilt motor assemblies so they are rebuildable. There are some brand names on some. I suspect there are some companies out there.
    I do find rev'ing the engine increases the window motor speed. Of course this increases the alternator output and voltage. Has anyone gone to an high output alternator and seen an instant fix on the window motor?
    I have 130 amp alternators on all my Foxes and although it does help it doesn't seem to make the old window motors function like new ones. Same is true for the window motors on my 86 Bronco (same exact motors as Mustangs). The engine running does make the windows roll up and down better, but they still drag at certain points and again are not fast nor consistent. That is 14volts of power compared to 12.6 volts.
    I would bet that Ford's rebuilds are nothing more than a good cleaning and installing new nylon bushings. I doubt they rewind the actual electric motors are even touch them. None of these are even rebuilt by Ford, just a third part vendor with the Ford label on them.
    All good points. Still running stock alternator for now. One day I’ll upgrade.
    Trey, completely agree on the ‘rebuilt’ stuff — especially electrical components. Such a loose term now days.
    I’ll just grab some replacements for now.
    Appreciate the feedback, fellas
    86 LX Coupe
    Jan 2004
    Olathe, Kansas
    Just put a new window motor is sons CVic. Newer style motor from NaPA. Works great, fast and smooth. Lifetime warranty. Like around 44$
    Now stang-less.
    88 Cougar 5.0
