Results 1 to 14 of 14
    Default Rear axle question
    I just got my '85 GT off the transport truck and realized an issue... The rear axle is locked. if rolling straight forward or reverse the rearend is silent, but when turning there's a racket coming from the back of the car (could just be tire noise). I've verified that the brakes are not dragging. I've verified the parking brake is free. I jacked the car up and the wheels turn easily, but there is no differential action. The wheels turn 1:1 side-to-side (turn the left wheel forward and the right turns forward). I see no leaks from the pinion or cover, haven't pulled a wheel yet, but the rear brakes wok fine, so I'm assuming no leaks t the axle seals.
    Would the trac-loc lock up if there was no friction modifier in the gear oil? Or would it need fresh oil/modifier? I assume that the trac-loc wouldn't engage if the friction modifier was old or nonexistent, or am I wrong, would it stick locked?
    FEP Power Member 86-TC/SVO's Avatar
    Aug 2010
    Connellsville, Pa
    Are you sure it's not an axle bearing ? My Dad's 88' TC had a noise from the rear end and it was an axle bearing.
    86' SVO 1C # 17 of 3379 86's #6475 of 9837
    86' SVO 1C #497 of 3379 86's #6955 of 9837
    84' GT Turbo #4 of 3241 GT Turbo HB's #560 of 3935
    87' Thunderbird TC 1 of 10
    http://www.foureyedpride.com/content...e-of-the-Month
    Barboursville, WV
    Doesn't take much to pop the cover off and have a look. Might be really obvious.
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    I'm trying to avoid removing the cover if all I need to do is add friction modifier...
    Mar 2003
    Lowell, Oregon
    It would be best to just pull the cover and look otherwise. It's pretty easy.
    The modifier might make it quieter is all, it might not.
    Saying it makes a racket is not a good description of the noise.
    I see Accel? Braking? Turning? All the time?
    Barboursville, WV
    Quote Originally Posted by TxMike64 View Post
    Lack of friction modifier won't cause them to lock up. They just chatter, as far as my experience goes. If you're dead set on not pulling the cover if you don't have to, another thing you can check is the pinion bearing. Grab the driveshaft near the rear u-jount and try to move it around. If the pinion has a lot of play in it, the bearing may be toast. If the pinion itself is loose, the ring gear can contact the carrier and cause binding/lock-up.
    If the car is new to you, removing the cover is your best bet. No telling what a previous owner may or may not have done.
    Friction modifier is actually designed to allow the clutch discs to slip more to remove the chattering during cornering that can happen and the associated noise that accompanies it. Friction modifier will actually allow the disc to wear a bit faster (NOTHING EXTREME), but they can wear faster due to the discs slipping more than just locking up and grabbing. No different than constantly slipping the clutch when taking off from a stop.
    With that said, it sounds like something is not right with the differential and I would highly recommend pulling the cover and inspecting as others have mentioned. Hopefully whatever the issue is can be corrected easily and before significant damage occurs. Good Luck!
    Yeah, I'm not averse to removing the cover, I just don't want to do it if it's just a matter of adding FM. My real intent in asking is to find out the failure mode of the Trac-Lok (slipping or sticking).
    "I see Accel? Braking? Turning? All the time?"
    I've checked under accel, under braking, reverse, forward... If you're going straight its silent. As soon as you start turning you hear tires scrubbing and groaning coming from the rearend.
    I would think if the pinion bearing is loose driveshaft clunking would be heard when shifting into drive, or when loading the drivetrain (like power braking).
    I have an 8.8 out of a '96 but I was wanting to put gears in it before having to swap it in.
    My real challenge is that I use a wheelchair and can't get up/dwn off the ground to work under the car in my garage. I have an arrangement with a local shop to use a lift on the weekends if any are open, but they are stacked-up with work which has kept me from being able to use an open lift. I may need to invest in a lift for my garage.
    May 2016
    Lake City Pa 16423
    I'm surprised that no one here mentioned the possibility that you may have a spool in there. No clutch packs or open diff.
    The rear in my 85 was making a lot of noise, snapping and popping. Only required adding of friction modifier.
    The rear in m6 85 was making a lot of noise, snapping and popping. Only required adding of friction modifier.
    I'm going to try it. Might as well... might buy me some time while I rebuild my 8.8.
    Quote Originally Posted by dynodon64 View Post
    No. This car is a cream puff stock car. And I asked the PO, he said "it was dry" and "sticky". But an older guy who wasn't very mechanically inclined.
    The cars I've driven with spools don't groan like this thing does...
    Barboursville, WV
    I misunderstood when you said it was locking up. I thought you meant the rear end itself was binding...as in, something catching and stopping it from rolling.
    I don't think you can tell if the trac-loc is working properly by turning a wheel with the rear tires off the ground. Have you checked the fluid level? I would start there. Dump a bottle of friction modifier in, along with any fluid that needs added. This is in lou of pulling the cover, inspecting, and refilling with fresh oil, of course. (In fact, the first thing I do after buying a used vehicle is change all fluids... even flush the radiator.) I'm sure you do the same, but I totally understand your situation. These are crazy times in the car/repair/service industry... and many other industries. I couldn't even get a dag gone haircut the other day lol!
    Sounds like a spool. I hate removing covers too, but it's not that bad. Plus, you'll really know what's going on.
    Theodore J. Garbera, 1985 Mercury Capri RS
