When I pulled my smog pump out of my ‘83 I broke the choke tube that goes from the exhaust manifold to the port by the choke. It broke clean off and I have no way to remove the end from the manifold. Are these tubes needed to make the car run and do I need to replace them? Or can I just throw some vacuum plugs over the ports of the carb and ignore it? In the photo you can see the flare is where it broke so if I need to replace it does anyone have any recommendations on how to go about doing that?
