Results 1 to 12 of 12
    Default Non H.O to H.O piston/rod swap?
    Found out my 84 Mustang has a 91 Non H.O Crown Victoria engine in it. My plan was going to upgrade the Heads/Cam thinking i had a legit 91 H.O engine. Question is can i just swap out the piston/rod assembly from a 87 and up H.O engine and not touch the crank or will I need to balance the assembly. I'm Thinking since the Crank is the same from a H.O and non H.O just to leave it alone and being these engine are externally balanced, does this sound right?
    1984 Mustang Convertible 5.0 5spd
    2000 Mustang GT Convertible Procharged
    2005 Mustang GT Full Bolt On's
    2002 Vette Convertible Vortech on Methanol
    Barboursville, WV
    I believe that would be a lot of work for little benefit, other than the forged pistons. If you feel you need forged pistons, I would suggest buying new pistons and rods (along with new bearings and upgraded rod bolts). If you're sticking to naturally aspirated, then the cast pistons will be fine. I can't seem to find info on compression ratios of HO vs non-HO, but I'm betting there's not much difference (if any). Some smaller-chamber aftermarket heads will increase flow and cr dramatically. Your cam choice will most likely switch you to the HO firing order. As long as the current engine is healthy, just do heads, cam, intake, etc and enjoy.
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    Quote Originally Posted by stang80s View Post
    The Crown Vic engine will have different clearances for non forged pistions, so a swap over is unlikely without re-establishing clearances to Forged OEM 1991 spec from a 5.0 HO.
    Double check:-
    1. Check head castings if OEM original. E6SE = 1986 (all passenger cars) or 1987+ non-H.O. (passenger cars)
    2. Cam, if OEM, is non HO firing order
    3. If engine is OEM, Grey pan, forged. Black pan, Hypereutectics
    Quote Originally Posted by Hissin79
    Starting in late '92 is when the switch to hypereutectic pistons was reportedly made. Before that, aero foxes had forged slugs.
    The old quick and dirty visual test is if the motor has the original and unmolested oil pan, if it is grey in color, that suggests forged slugs. If the pan is black, that suggests hypers.
    4. E7TE = 1987-90 (all passenger cars and trucks), after that, F1xx, post 1990
    5. The forged piston part numbers are:
    1985: E4ZE-6110-SA or SB; first year 5.0 got forged pistons, 2 valve reliefs cut into the tops and compression stayed 8.4:1
    1986: E6ZE-6110-BA No valve reliefs
    1987-92: E7ZA-6110-CA, some have a PA suffix. Forged four eye brow.
    Good fortune tracking the exact origins.
    What exactly are you trying to achieve?
    John Adams
    July 7, 1775
    The Engine block is F1SE, Heads are E6SE and pistons are dished non valve relief as verified by using my borescope. I do not want to flycut these stock cast pistons. I plan do upgrade to AFR190 Heads and a E303 cam which most likely not work with the current pistons as there will be PTV interference. I just picked up a 1985 OEM Forged Piston set with Rods along with the OEM crank and will stuff the Pistons/Rods in the block and check the existing crank for wear, if all good then leave the crank in place, Of course all new bearing throughout.
    Where is the parts number located on the piston? Is it under the crown? I need to verify the 85 Pistons just to see if they are 1985 or 87 and up
    Barboursville, WV
    What makes you think you will have ptv clearance issues? That's a pretty mild cam. I couldn't imagine it being a problem. I'm pretty sure folks have ran the e303 with the 86 HO flat top pistons (no valve reliefs). Anyway, seeing as how you have the rods and pistons already, it wouldn't hurt to upgrade while you're going through it.
    Jul 2010
    Houston (Clear Lake), Texas
    Forged pistons...I believe they are the hyper units in that year...
    HAD
    HAVE
    Jul 2010
    I have the E303 cam in my engine with stock 1985 slugs and GT40p heads and its been all good.
    The piston parts number is in the center top portion of each slug...along with the oval Ford signature below...as seen in a picture of my stock 1985 short block power plant as attached...
    Name:  Stang engine short block.jpg
    HAD
    HAVE
    Feb 2009
    Jackson, NJ 08527
    Weren't 85's these forged one's?
    1985: E4ZE-6110-SB
    Jan 2004
    Olathe, Kansas
    1985: E4ZE-6110-SB
    I thought the 85s with 4 barrel were forged pistons.
    Now stang-less.
    88 Cougar 5.0
    Jul 2010
    1985: E4ZE-6110-SB
    Yes, the 1984 and back were cast slugs...basically flat tops with 4 valve reliefs. In 1985 they were the same design...flat top with 4 valve reliefs...but forged. The 1986 units did away with the 4 valve reliefs. In 1987 they were still forged but had a center dish relief in the top. What I was talking about in the aforementioned post is that later on they went to the hyper slugs...
    HAD
    HAVE
