Results 1 to 4 of 4
    Default 82 Gauge Cluster issue
    Recently i installed new plugs on my harness at the gauge cluster. Took some trial and error but got it done. I have pin locations correct but my temp no longer works and low fuel light is all ways on now.
    The fuel gauge is working and its my understanding that this indicator light is controlled with the gauge.
    Have no clue on temp gauge, no blown fuses or bad wires that i know of and it worked before so.
    I am considering just swapping out to auto meter gauges but would rather stay with stock.
    If you have any advice i would appreciate it
    FEP Member Hans's Avatar
    Jun 2008
    the Netherlands
    Could it be a ground issue?
    I have seen schematics on this forum. If not done already you can see there how the gauges are wired to look for answers.
    Sorry, my 79 never gave any reason to look into this.
    My understanding is the info center uses the ohms resistance to determine when to illuminate the lights such as low fuel, resistance due to a blown bulb will illuminate the lights for bulb out, etc.
    If the fuel gauge is reading correctly and working properly, then most likely the info center is seeing a resistance issue due to the new plug or connections. The same may be true for the temp gauge. You might try using a Power Probe or similar to give voltage directly to the temp gauge sending unit wire and see if the gauge responds. As noted by Hans it could also be a ground or intermittent ground issue. Good Luck!
    New User
    Nov 2022
    Charlottesville, VA
    You would probably have more luck if you move this to a different forum
