Starting some refresh work on my new to me 83 GLX Convertible, and I have a couple of questions:
- What is the size of the star-shaped bit needed to remove the front seat seat belt receiver (female end, mounted on transmission tunnel by the console)? I have to buy a bit to be able to remove and replace the broken plastic sleeve, and need to know what size to get.
- What is the trick to removing the factory auto shift T-handle? I was told to push in the thumb button and pull up on the T handle, and it would pop right off. Not so much; it doesn't budge even a little bit. Not sure what I am doing wrong but could use some advice here.
Thanks in advance.
