Results 1 to 4 of 4
    Default 85 mustang gt oil smells like gas
    Hi I changed my engine oil and I noticed that my oil smells like gas. It’s not flammable so it’s probably not much. It is running a little rich so that might be the issue? I have a Holley avenger 670cfm could it be my floats? The gas is in the middle of the site glass
    Mar 2003
    Lowell, Oregon
    Check the floats for sure. If they are not shutting off fuel flow when the bowls are full you get gas in the oil.
    Mar 2008
    darien il
    if your 85 is a car with a carb. the fuel pump can have an internal leak that will put gas in your oil. stock 85 with a clutch has a mechanical fuel pump, the automatics do not.
    May 2016
    Lake City Pa 16423
    Fuel level is too high. It should be at the bottom of the sight glass, level with the bottom of the hole. This won't cause the fuel smell in the oil. Fuel boiling will over flow the fuel from the bowls, but if that happens, it will flood the engine and be hard to start.
