Results 1 to 9 of 9
    May 2005
    Altoona, PA
    Default Scott Rob or similar dash. Who has them?
    For years I've been thinking about putting a sheet metal dash in my car, and I think the time has come when I may actually do it. I did a little searching and found this thread from 7 years ago:
    http://vb.foureyedpride.com/showthread.php?163019-Scott-Rod-Dash-Installed-Pics
    I do like the looks of that dash and wondered if any members have used that one or similar, if there are others making something like that. My dash right now is super beat up so it's not like I'd be tearing up anything nice to make the change. At present my 5" tach sits on top of the dash soon to be accompanied by my new A/F gauge, and I have a row of switches where the radio sat at one time, plus I have a trio of gauges mounted over above the glovebox that are hard to see from the drivers seat. All my gauges are Autometer, so I can buy a 5" electronic speedo that matches everything else and install them all where they should be, in front of the driver.
    Here's my present setup:
    Thoughts?
    408/T5/3.73's
    I have no personal experience with any of the metal nor fiberglass dash replacements, so I can't help there.
    I have considered the fiberglass option from VFN for a future project, but haven't gotten to that just yet. https://www.vfnfiberglass.com/7986mustang.htm
    Good Luck!
    May 2005
    Altoona, PA
    Thanks for pointing out that option. One reason I started this thread was to pick some brains about other options I might not be aware of.
    408/T5/3.73's
    Does the windshield need to be removed to rivet in these aftermarket dashboards? Those rivets look awful close lol
    FEP Power Member racerxmd's Avatar
    Sep 2007
    Rockville,MD.
    Why not a fiberglass dash like this:
    http://www.vfnfiberglass.com/7986mustang.htm
    Quote Originally Posted by racerxmd View Post
    Hmm if only someone had posted about that before . . . Maybe in post #2!
    Great minds think alike right!
    Hahaha
    May 2005
    Altoona, PA
    I hadn't even thought about a fiberglass dash, so that's another option. Which is why I started this thread, to get ideas.
    That does look like a problem and I have no intention of removing the windshield. I'd probably use screws instead of rivets so it would be easier to remove if I wanted to work on the wiring at some future date. I'd do almost anything to avoid having to lay on my back working under a dash. Perhaps with screws an offset screwdriver would work.
    I'm leaning towards the two piece metal dash at this point but I'm not in a hurry to decide.
    408/T5/3.73's
    Maybe they get riveted from underneath?
