Results 1 to 8 of 8
    Default 1982 gt 5.0 4 spd idle surging and stalling
    I have a bone stock 1982 gt. I bought it last year and everything ran fine it has 3500 original miles. I parked it for the winter and it ran fin for the first 10-15 minutes. Now it has a surging idle bouncing between 750 and 1500 rpm. It stalls if I dont have my foot on the gas pedal and it will die if i push in the clutch when coming to a stop. However unplugging a vacuum line clears up the problem completely. It will drive and idle fine can anyone give me an idea whats going on
    Oct 2010
    Lebanon, IL
    Running too rich if a vacuum leak fixes the issue. Check the choke to make sure its not sticking. Check float level. Check fuel pressure
    BBD PERFORMANCE
    HIGH PERFORMANCE PARTS
    CUSTOM ENGINE BUILDS
    CUSTOM CAM DESIGNS
    1983 CRIMSON CAT OWNER
    Jul 2010
    Houston (Clear Lake), Texas
    Quote Originally Posted by Davesgro View Post
    Wow...would love to see pictures of that one! ^^^...But yea, what he said...
    HAD
    HAVE
    Quote Originally Posted by Ethyl Cat View Post
    Thanks going to look at it today. Im not a mechanic but i can try. Should it need adjusting if its never been tampered with?
    My guess, blown power valve. Buy a rebuilt kit for that 2V carb and do a quick rebuild. It is easy and quick and it will run great afterwards. The power valve enrichens the mixture when you are on it hard and the vacuum drops. When it blows (leaks), it causes the mixture to go extreme rich, thus when you introduce your vacuum leak, you lean it out to a runable mixture.
    Kenny
    Kenny
    Back in the day I think I put a half a dozen of those in my '83 GT. Was a common problem. For some reason it was prone to back pop through the carb, which apparently will kill a power valve.
    Quote Originally Posted by mustangwolf View Post
    Every freaking time until they started installing the blow out prevention check ball. My early Holley's ate 1 a year. It is the same reason I bought my daughter's 83 Capri so cheap: It would start fine then slowly run worse and worse until it just wouldn't run. The owner took it to a few people but no one figured it out... I knew the problem as soon as I smelled the exhaust. WooHoo... deal for me!
    Just to be clear, the Autolite 2V carb also has a power valve, not just Holleys.
    Kenny
    Having similar issues with my 85 GT convertible. Bought it last fall and ran well until put away for the winter. Now have had it out a couple of times and it will periodically surge or die at idle. This past weekend I could only get a mile or so from home before deciding to turn around and head for the stable. I have a Holley and 5 spd. Have only put non-ethanol premium in the tank. Wondered if there was water in the lines. Thanks.
