Picked up an 8.8 traction loc axle with 3.08 gears to swap into a 79 Mustang with factory 7.5 axle. The factory hard brake line the rubber hose from the rear axle connects to disappears into the passenger side rear floorpan. Whats the cleanest option, run a new later fox hard line from front to back under the car and use factory center junction on 8.8 to connect to for rear brakes? Car has been stored inside for 25 years, but I can see possibility of twisting off factory hard line to rear axle that disappears into floorpan.
