Results 1 to 9 of 9
Thread: Windage Tray?
    Talking Windage Tray?
    So, I’ve been sitting here recovering from a broken ankle, watching reruns of whatever. There is an episode of Engine Masters where they swap the standard oil pan out for a pan with a windage tray, then another episode where they put on a wide body oil pan. Engine is put on a dyno and compared. Horsepower and torque are improved at all rpm by a surprising amount. 22 hp and 11 ft-lb gain going to the wide body. this is on a big block Chevy that can rev to 8k rpm. Just wondering if anyone is running a windage tray and are you seeing any benefit? Canton and Milodon are a couple of manufacturers, and for the money, it is a low cost way to pick up some power. I hope this isn’t too big a can of worms. Or maybe I do!
    W
    I saw that as well... If had a chance to do it over, I would definitely definitely add that to my rebuild.
    Barboursville, WV
    I watched it. Very interesting episode, as always. Didn't he mentioned that oil pan was $650?
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    Yes I think so. But that was a 2 part pan with the windage tray built in. Over the stock pan, I think they were able to add over 30 hp to the dyno. Sounds like a no-brainer if you are building a serious racing engine. LMR shows a windage tray kit for $130. No idea what the hp improvement would be, but, a 15 hp improvement would be a nice help. Better to put it to the rear wheels instead of churning and heating the oil.
    W
    Barboursville, WV
    Quote Originally Posted by WilliamCapri View Post
    It was also interesting to see how too much oil was robbing hp. I watch very little tv these days, but this is one of only a few gems. Roadkill garage, Hot Rod Garage, Flipping Bangers, old episodes of Wheeler Dealers (with Edd China) being a few others.
    Aug 2004
    California
    I put a Milodon "road-race" kick-out pan on my 8.2 deck stroker. Holds 7 quarts before the filter, has baffles and trap doors to keep the oil around the pick-up. Is only 7" deep so lots of ground clearance. Seems to work great but there is no way to measure what if any improvement had I done a stock pan instead. I think I would do a kick-out pan again but not sure if a windage tray is necessary for primarily a street car that sees some autocross and open track. I wanted the extra oil and confidence that the pick-up was swimming in oil during hard corners. Not looking for the last .5 HP/TQ which is where windage is an issue.
    Quote Originally Posted by qtrracer View Post
    Did you have any trouble with the Milodan Road Race pan kickout hitting the rear of the K member on the passenger side? I am having an issue with that in my 83 GT. Building a 347; right now I have a mock up block in with the Milodon pan attached. The K member, which is thinker on the passenger side, and the steering rack bolt head (M16 with integral washer) is hitting the oil pan. I can cut away the k member and plate it but the rack bolt is more problematic.
    Aug 2004
    California
    No, but I'm running an MM K-member on my 86. Also have a 347.
    Oct 2014
    Calgary, Alberta, Canada
    I'm running a similar Moroso pan with the MM K-member. I did need to trim the ends of the rack bolts off to clear, but that was it. It does make the starter a challenge to get to though.
