    Jun 2013
    San Diego, Ca.
    Default 351W Lightning connecting rod info needed.
    Ok guys, I'm in need of some info on the 351W Lightning connecting rod (lol, as the title reads). I'm in the planning stages of a stroker (for use under 8 psi or less) in the 393W area.....
    Anyone with actual hands on experience (nelzfox, etc.) reach out to me in a private message. I'm not on here a lot, so patience will be needed.
    Thanx
    conmech - aka Marshall
    My information is the Lightening rods are no different than regular 351W rods. I am pretty sure they are standard Ford with no improvements or anything special.
    Just buy a set of ARP rod bolts, have the rods resized and call it good unless you are planning on spinning some major RPMs. Good Luck!
    Jun 2013
    San Diego, Ca.
    Plans are for the '23 T bucket after the RS is done....
    .020" over Ross racing forged pistons (5.0L pin location)....wanting around 391W with twin T3's.
    The 393 stroker with that combo is a low-mid range torque monster. Are you sure you will be able to put all of that to the ground in a T bucket. Then add any boost on top of that? Bad A$$ for sure, just need to make sure its not just a tire smoking machine IMHO. Good Luck!
    Jun 2013
    San Diego, Ca.
