Results 1 to 12 of 12
    Default 86 aftermarket heads
    Ok I have the stock bottom end 86 with the flat top pistons and no valve reliefs, not changing cams going to use stock cam until short block is done 3-4 months out
    Is there an aftermarket aluminum head I can use on the stock pistons now? Some people say trick flow 170's but what is the part number for them if they do work?
    Aug 2004
    California
    Don't know about TF, but I used E7s on my 86 along with the 87+upper and TB, DA1 computer, and BBK unequal shorts. Had plenty of valve clearance on mine.
    Made a huge difference in low and mid-range performance.
    Quote Originally Posted by qtrracer View Post
    Actually I can get a set of them that were just rebuilt and trick flow springs installed with mild porting, but my shop guy says still taking a chance if they will even work and may pick up 15-20HP?
    I already have a cobra intake, 70mm TB and BBK long tubes 1-5/8"
    Aug 2004
    California
    Quote Originally Posted by pay1973 View Post
    You can get E7s or the TF? I never had mine dynoed, but SOP sure felt more than 20HP up to about 5600 when it just ran out with the stock cam. I also had 3.27 rear gears. The E7s are tight without reliefs but if the deck is stock height, heads not milled and you run a replacement head gasket with the stock cam and 1.6 rockers you should have enough clearance. The E7s boost CR a little too. However, if you don't have the above dimensions and/or run a 1.7 rocker, it might be too tight.
    Feb 2009
    Jackson, NJ 08527
    I have the TW170's, stock cam, and 1.7 rockers on my 86. No issues
    I have the Trick Flow 360 HP Top End kit on my 86 GT which includes TF 170s, TF track max cam, TF track heat upper/lower intake in black powder coat, TF valve covers, and all the other nuts and bolts that comes with the kit.
    1986 Mustang GT -DGM- Trick Flow 360 HP Top End Kit. TF 170CC Heads, TF Track Max Cam, TF TM Intake
    1999 Mustang GT -Garrett 67mm Turbo, E85 on 18lbs, Built SB, Cammed, 03 Cobra IRS, 675 RWHP- SOLD
    2013 Subaru WRX -FMS TMIC, Cobb AP, Full TBE -Catted DP, Whiteline Suspension Mods, 308/339-TOTALED.
    2012 Mustang GT -SCT X3 Bama Can Tune, JLT CAI, Barton Short Throw Shifter, Roush Axle Back -SOLD.
    can I please get the part number, I called trick flow cannot get through and left message with them and no call back.
    I appreciate it
    I believe you can also use the GT40 heads from an Explorer.
    Do you have the M61 or M58 heads? and you have stock 86 pistons flat top with no valve reliefs?
    Ok so found a good deal on a motor that should hopefully get me where I want
    302 stock bottom end rebuilt (out of 92)
    trick flow stage 1 cam
    Edelbrock 60399 alum. Heads
    Cobra Intake
    BBK 70mm TB
    bought mass air conversion A9L with Pro M wiring kit
    Pro M 75mm mass air meter calibrated to 24# injectors
    24# injectors
    Long tubes
    off road X pipe
    Car has 4.10's 5 speed MT ET Street SS 255/60/15 and race star 91 skinnies up front
    High 12's possible?
    Barboursville, WV
    Hot Rod Garage did a build with a carbed 85gt. I believe they used Trickflow heads, but 3.73 gear and they went mid 12's with very little tuning. You should be able to do that easily with 4.10's and some tuning.
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
