Results 1 to 15 of 15
    Feb 2018
    Saskatchewan, Canada
    Default Clutch options for a 85 gt with a 4 cylinder t5
    Hey guys, one of my many projects coming up is to put a new clutch and all the fixins like throw out bearing, pivot stud, cable etc in my sons 85 gt. Car has a t5 from a 4 cylinder in it(previous owner) Is there any difference as parts go for a 4 vs a 8 cylinder t5? Thanks
    Mustangs
    84.5 Gt T-top
    85 Gt
    Jul 2010
    Houston (Clear Lake), Texas
    External parts should be the same.
    HAD
    HAVE
    Mar 2003
    Lowell, Oregon
    If you have a flywheel for a 10" clutch use that. If your flywheel is for an 10 1/2" clutch use that. I think '87 was the first year for a factory 10 1/2" .
    Your 85 should have a 10"
    Like said above all the other parts are essentially the same.
    Feb 2018
    Ok, thanks. Was not sure because I read input shaft is different size on the 4 banger t5's. I'm going to be replacing flywheel with the clutch as well so I think I'm going to go 10.5 and 157 tooth.
    Mustangs
    84.5 Gt T-top
    85 Gt
    Be sure to check out the pilot bushing closely in the flywheel when you have it apart. The 4 cylinder T5 has a different (smaller) input shaft tip and uses a smaller pilot bushing from what I have read.
    If someone just put in a 4 cylinder T5, but you still have the V8 pilot bushing, then it will not fit correctly (tight enough) and could cause all kinds of wobble issues.
    That is if your continuing to use the 4 cylinder T5...
    Feb 2018
    Quote Originally Posted by at_the_junkyard View Post
    Ok, ya that's what I was reading earlier. Will have to check that out when its apart. Can you get the pilot bushings for the 4 cylinders still? Planning on still using the 4 cylinder t5 for now. Put new clutch and everything in and see how it performs.
    Mustangs
    84.5 Gt T-top
    85 Gt
    Maybe others can verify but I think if you spec out a pilot bushing from a 2.3L mustang with a T5 that it will still fit the V8 crank.
    Getting the old one out might be a challenge though.
    Feb 2018
    I've been just itching to try the bread trick lol
    In all seriousness though, as long as the flywheel is in decent shape we will probably just keep using it. Just need to find out what size is in there I guess.
    Mustangs
    84.5 Gt T-top
    85 Gt
    Apr 2010
    Portland, Oregon
    The 2.3 pilot has a MUCH smaller OD & ID. The "standard" solution is to use an 84-ish Ranger Perkins diesel pilot (search this site for "diesel pilot" - but beware, lots of misinformation comes up with that search).
    A 4-cylinder T-5 with a 5.0 must be really unpleasant in 1st gear (3.97:1 vs 3.35:1).
    Feb 2018
    Wouldn't really know lol, have only drove it about a block since we've owned it
    Mustangs
    84.5 Gt T-top
    85 Gt
    Mar 2003
    Lowell, Oregon
    If your running it behind a V8 why not get a V8 trans so all works better together?
    FEP Member bkm's Avatar
    Jan 2016
    House Springs MO
    The 4 banger t5 can be a fun stop light to stop light transmission with stock gears. Anything above 3.55 and first is like granny low. I used the Ranger diesel pilot on my 86 years ago. I needed transportation and the 4 banger t5 was a cheap stop gap till I could get my v8 t5 fixed.
    Feb 2018
    That's eventually the plan but where I'm from they are not easily found and often people want way more than they are worth. Just like the cars themselves. This is just a temporary solution.
    Mustangs
    84.5 Gt T-top
    85 Gt
    Mar 2003
    Lowell, Oregon
    Makes sense.
