I have a good A9P wanting to trade for a good A9L for my 5 speed Mustang.
Matt
Not sure what your plans and goals are, but I have run the A9P with the T5 with no issues at all. Most rumors/internet lore states the A9P has more timing than the A9L, but I can't personally verify that. I didn't notice a huge difference between the two computers with my T5, but I honestly don't think I would go through the trouble to swap one for the other in most cases. Just my .02 good luck!
Trey
I don't think you are going to find anyone willing to trade down unless you are willing to front some extra money in on the deal.
Trey
I agree with Trey. I didn't see any difference at all. Not worth the hassle to try and trade and put up some $$.
