Results 1 to 6 of 6
    Default Ridge reamer. Is it necessary?
    What do you guys think? Will I need to removed this slight ridge before taking out the pistons? I can just catch my fingernail. But I've seen some people say that if you plan on putting the original pistons back in, it's not completely necessary. I'd just rather not buy a 70 dollar tool that I'll only use once
    Sent from my SM-G950W using Tapatalk
    Just try... Hard to see in pictures but if it is small the rings can go right by. If it is large, they will stop the piston from coming out. You won't be reusing the rings so no harm, no foul. If the ridge is big enough to stop the piston from coming out, you are probably going to need a bore, or your "rebuild" will not last long before the blue haze of cheapness with envelop you.
    Kenny
    If you do need one and dont need it for a couple of days, here is one for a bit less $$. https://www.amazon.com/Lisle-36500-R.../dp/B000P0ZK1O
    1984 SVO Awaiting Restoration
    Mar 2003
    Lowell, Oregon
    Or pull the pistons out the bottom of the block. Installing them could then be an issue if the ridge is too much.
    Hate to say it, but $70 (or less from Amazon as mentioned by Trey) is the cost of doing business. Do it right with confidence, or try to cut the wrong corners and pay a lot more later.
    Now an 1981 Granada! Building a 9.5:1 .040 over 302, Edel E-street heads, 268 cam, T5, 8.8 with 3.55, plus all the stiffening goodies, all control arms, lowered, alum shaft, x-pipe with Outlaws...
    Aug 2005
    Plymouth, Ma.
    If you need a ridge reamer, You need a bore job. Those things do more damage then they fix.
    85 G.T. All motor
    337 c.i.d 11.44-120 mph
    1984 G.T. (Daughters car)
    I completely agree with this. Wrong time to cheap out imho
    79 Zephyr, 4v/4r70w swap planned, with team z front and rear suspension, 8.8 and upgraded brakes and coil overs.
