I'm getting ready to weld the quarters back on my 86 capri. What is a good weld through seam sealer to use? Should I use weld through primer first? Any info would be greatly appreciated
3M weld thru seams sealer and 3M weld thru primer should be used together. The weld thru seam sealer must be welded while it is still wet in order to not completely burn thru the sealer. Here is a video that goes through the process.
https://www.facebook.com/3MCollision...0482951994002/
Good Luck!
Trey
Dang
i had no idea they made weld through seam sealer.
I ended up using 3m weld thru primer after testing several types. Luckily I was able to reach in and apply seam sealer after the fact.
great info thanks!
