Results 1 to 6 of 6
    Default 79 rack and pinion
    I'm installing a rebuilt rack and pinion in my 79 Pace Car. The pinch bolt at the rag joint appears to be a torx head or something like it. What size socket do I use to remove it? Any tips to removing the rag joint?
    Bob
    Unless I am mistake the bolt in question is a 12 point head. Just use a 12 point socket the correct size and you should be good to go. Unfortunately its been awhile since I took it off my PC, so I don't recall the correct size socket needed. Good Luck!
    Jun 2003
    Decatur Alabama
    7/16 12 pt socket
    Kendal
    Trey/ Kendal
    Thanks for your help, I even had the right socket to remove the bolt.
    Bob
    After several attempts, I'm unable to slid the shaft on my rebuilt rack and pinion into the rag joint. There is a bolt on the steering shaft at the firewall, will this bolt remove the steering shaft? Is it easier to remove the shaft and install as a unit?
    Any other advise?
    Bob
    Yes.
    I would remove the steering shaft from the car and test fit it on the rebuilt rack on a workbench. Then you can figure out what the problem is.
    Jack Hidley
