Results 1 to 8 of 8
    Nov 2010
    Citrus Heights, CA
    Default Condensation in low beam lights
    Hey all...
    I just noticed that I have condensation in my low beam units. The lights still work okay, but I'm guessing its not a good sign. I mean, they are 38 year old headlamps. What's the recommended stock replacement? Please...no discussion of upgrades.
    Many thanks in advance!
    Bryan
    1983 Mustang GLX Convertible
    I like the Sylvania ExtraVision lamps. It’s one of the better ones without going LED. Except for the print on the lens, they look just like factory. LEDs seem to stand out looking different.
    Nov 2010
    Citrus Heights, CA
    Kevin -
    Yeah, I was looking at those on the Auto Zone website. It looks like the main choices are eith Wagner or Sylvania. I kind of like the idea of the illumination quality being a bit better than standard halogen units. Thanks for the recommendation.
    Bryan
    Default standard 4 eye eyes
    Halogens here. Sylvania brand low, Wagner hi, Sylvania H3 fog bulbs work well. Discontinued GE's were good too.
    A bright traditional orange-yellow-white (warm) white incandescent output.
    Bluish light or super led harshly being cast onto the road is hard on my eyes but they are ok if you like them.
    Theory- condensation eventually may cause beam reflectors to gradually turn black, causing dimming, and look bad.
    Although rarely used, replaced both working high beams because both of the reflectors were black looking like that.
    Like two black eyes, inners did not match outers when front of car was viewed from a distance.
    Color-Prefer warm white color in home and car. Using higher spectrum for special lighting needs.
    Color led for on/off item power in car, warm white led house lighting.
    Had a low beam glass lens fall right off once. Was a beam abandoned on my work bench. Surprisingly a name brand.
    Could seal it back on with rtv. Noted seal design was changed on newer product.
    My early 79 Cobra had standard factory conventional (at the time) tungsten headlights when i bought it.
    Did a lot of night work commute driving. Sold on the tech, promptly upgraded to GE halogens 1980 or so.
    But the graphic display headlight led stayed 1/2 lit going from conventional to halogen.
    Distracting. Read is was due to a resistance change. Did not know how to fix that. Change resistance? How, where?
    Much worse, headlights started failing almost every 6 months. First one, then the other. Had a whole milk crate of them.
    Years later by chance and a hunch found a badly failing butt wiring splice from a dealer collision ds apron repair.
    After close inspection of the main harness tape, found the problem two feet back from the radiator support.
    Think i unwrapped it fiddling with the washer fluid pump pigtail or something.
    As if that wire splice issue was bumming out the lights and the car too like a wound bleeding electricity.
    Did a new and better splice. Resolved. No more short life from headlights to this day and the graphic display red led went out.
    Felt like the car electrical was happy again after the doc solving a long time hidden mystery like that.
    Was not the 79 Pace Car the first Mustang to have halogen as std equipment?
    https://corporate.ford.com/articles/...g-history.html
    Would like to try out a headlight dual relay electrical update sometime.
    Would prob lose the red led headlight out feature of the graphic warning display, but trade off appears to be of greater usefulness, coolness.
    A bright traditional orange-yellow-white (warm) white output.
    My early 79 Cobra had conventional (at the time) tungsten headlights when i bought it.
    The graphic display headlight led stayed 1/2 lit going from conventional to halogen. Read is was due to a resistance change.
    Think i was repairing the washer fluid pump pigtail or something.
    Did a new and better splice. Mystery solved. No more short life from headlights to this day and the graphic display red led went out.
    I recommend doing the dual relays, makes a huge difference in the light output. The only drawback is that yes, the lamp out warning stays on whenever the lights are on. I only did it because I toasted 2 headlight switches in less than a year
    I think the first rectangular lights were on the Fairmont cars in 78. I believe halogens came out a bit later in the early 80s. They were advertised as a standard feature by 81.
    Default shedding new light
    Have decided would deal with the led warning and move the task up a notch in priorities.
    Actually the lit led would work as a headlight reminder. Plus mod is reversible.
    Seems like every 10 years, head lights have to be upgraded somehow to shiny new car like operation.
    They were fine when the car was new (so were 40a alternators) and are the same now.
    Upgrade to relays cost seems reasonable.
    Wired a fog light kit, am using a relay to power a custom 2nd fuse panel. They make nice things happen.
    Even if you use the halogen bulbs, the output with relays (to my naked eye) is better than some cars MY 2004-05. That is also assuming you have a 90-130a alternator also.
