Can someone decode these for me?
1979 Ford Mustang Pace Car
4.6 2V conversion underway!!
It only takes me to photobucket and doesn't show any pictures. Maybe your problem is the file size is too large to upload. I download and resize my pictures thru MS Paint to 20% of original size and then I can upload it here fine.
Maybe that's my issue, when I try to upload to the site it say unable to upload. I'll give that a whirl.
Got it
VIN
9 = 1979 model year
F = Dearborn Assembly
02 = Mustang 2-door sedan (coupe)
F = 5.0L V8 engine
248207 = 148,207th 1979 Ford scheduled for production at Dearborn Assembly
Door Tag
Date - 03-79 = March 1979 build
GVWR - 3871 lb/1755 kg = gross vehicle weight rating
Front GAWR - 2074 lb/940 kg = front gross axle weight rating
Rear GAWR - 1817 lb/824 kg = rear gross axle weight rating
F0123 = 0123 lbs front accessory reserve load
R0078 = 0078 lbs rear accessory reserve load
Exterior Paint Colors - 1G = Silver Metallic
DSO - 48 = Detroit district sales office
Body - 66B = Mustang 2-door sedan
VR - [blank] = no vinyl roof
Mldg - 73P = Black bodyside molding, Argent inset stripes
Int Trim - BD = cloth seating, high-back front buckets (B), Medium Red interior trim color (D)
AC - [blank] = no factory air conditioner
R - [blank] = no factory radio
S - [blank] = no sunroof
Ax - Y = 3.08:1 axle ratio, conventional (non-locking) differential
Tr - 5 = manual overdrive transmission (Tremec SROD 4-speed)
ZZ = front springs
FF = rear springs
Buck Tag
MUSTANG = Mustang model line
212689 = 112,689th 1982 Ford scheduled for production at Dearborn Assembly
61B = Mustang 3-door sedan (hatchback)
F = H.O. 5.0L V8 engine
TR = T-roof
0249 = body & paint rotations #0249
1G = Silver Metallic exterior paint color
DF
ST
AC = manual air conditioner
04 = rear wing (no rear defrost, no rear louvers, no rear washer/wiper)
S = speed control (cruise control)
GT = GT model/trim level
MOD = manual overdrive transmission (Tremec SROD 4-speed)
05 = hole in hood covered by forward-facing non-functional hood scoop
-D = Medium Red interior trim color
NLR
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
I'm so confused by some of what you said due to what's there and what's not there.
This was a non ac car, but does have rear defrost, no sunroof. I bought the car from the original owner she was a sweet old lady in her 70s.
I wonder if the Buick tag even belongs to this car now.
Actually according to what is stated it indeed doesnt belong to the car... idk how it can be on the car...
Was the car ever in an accident and have the front end or rad support changed? That would explain the 1982 hatch buck tag. From the look of the pictures it has been repainted.
Were T-tops available on 79 coupe's? Interesting.
84 Capri RS Turbo
USAF 1986-2007 (Ret)
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
So the buck tag and decal are mismatched?
84 Capri RS Turbo
Yes, it appears so. Door tag is from a 1979 5.0L 2-door sedan (coupe). Buck tag is from a 1982 5.0L GT.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Did some checking.... the front core support has been replaced at one time, I'm not sure when but whoever did it did a decent job on the repair.
That could explain the mismatch. I knew T-tops didn't appear in 79, so this post threw me some.
84 Capri RS Turbo
It's rare as this 79 has parts from an 82 gt t top car, that just added like $2,000 to its value.... hahaha
Check my footnote I6 81 Mustang ITZOLD.
Check the frame tags. Read the article. I dont want to tell others how to commit felony offences. My car was exported to Japan, and had its 1981 Hatch body VIN tag swapped for another 3.3 auto 1982 coupe's body VIN tag. The VIN tag doesnt match the engine.
The engine number and frame horn tags govern what the car is.
Buck tag and screen VIN can be changed when a car is almost or actually written off.
Its easy to flim flam some little old ladies. But also carear engineers like me who should have known better.
But like you, who wouldn't enjoy a Four eyed Fox for sale?
Having a VIN tag of a different year and body type is possiable after the car is built if its had an accident. Its not 100% that your ride is cut and shut. Its probably due to some other matter. O dear me, what can the matter be...?
Follow my thread, and do your research with Fox Chassis help. The truth is out there!
For me the X-files are xctasy!
I have a clean title for this car and the 2.8 auto hatchback I got as a package deal, the title matches the door and the dash so that's all I'm really worried about as far as ever registering it or anything.
