Results 1 to 3 of 3
Thread: Connection
    Sep 2011
    Clarksville Indiana
    Default Connection
    Where does the main engine wiring harness connect to the harness that goes to the ignition, dizzy coil etc on 85 gt? Is it right outside of firewall or inside of firewall?
    Sent from my Pixel 3 using Tapatalk
    There should be an engine harness disconnect on the driver side inner fender just in front of the Master Cylinder. Here is a link to a reproduction engine harness. You can see the connectors on the left side of the picture that would connect to the main harness.
    https://www.foxresto.com/1985-Mustan...-p/4785002.htm
    Sep 2011
    Clarksville Indiana
    Thanks I appreciate it. That's the harness I was looking at getting. Several of my wires are brittle. From the main harness back I think they're good.
