Results 1 to 13 of 13
    Default H pipe hangs low drivers side
    H pipe hangs low on drivers side any one else have that prob 84 with shortie headers
    LIFE IS ONE LONG WEEKEND
    Although mine are bbk, the installer did quite a bit of tweaking to make them work.
    Jul 2009
    Cherryville n.c.
    I had 2 different set I tried on mine never could get them to fit right. I took it to a muffler shop and he butchered them and welded them back together fits like it was made for it now.
    was the prob always the driver side. I dont see any way but to cut them and weld back
    May 2016
    Lake City Pa 16423
    The the pipe hanger at the trans mount still there? It helps hold up the H pipe.
    yes it is. left pipe just does not fit up to the crossmember
    The car is not on all 4 yet so cant take it to muffler shop yet
    I've yet to have an exhaust system that fits perfectly. I've had to tweak all of mine. Flowamster, bbk, magna flow, etc.
    china dosent build them like they use too
    Fwiw, a properly fitting Fox Mustang is like "World Peace". It exists only in the minds of naive people that don't know better.
    The factory exhaust had to be replaced on my Mustang ~5-7 years after it was new. I forget when/why.
    The Service Advisor said that even the exhausts from the factory "had to be tweaked" (cut/welds/etc).
    Also, a very good "Mustang-only" specialist that I used to go to (he passed away :-( ), told me that every exhaust he did needed "tweaking". And, he had put on every Mustang exhaust system that was sold.
    He used, and suggested, good band-clamps. Beware, there are many cheap POS band-clamps.
    Use your sawsall and a good/new demolition blades. If someone doesn't have a sawsall, then buy one. Or, feel free to use your hacksaw and cut the exhaust (like I used to do when I was in high school).
    https://www.amazon.com/gp/product/B001808738/
    Vibrant 1171 Exhaust Sleeve Clamp, Pack of 1, Silver (2.5")
    Price: $28.95
    Good Luck!
    85 and older uses a heat riser valve on the right side. 86-93 stock or otherwise headers do not use the heat riser. 84-85 exhaust requires matching manifolds/ headers, heat riser and matching H (actually Y) pipe.
    the headers are the same length as my old 84 manifold plus the heat riser valve
    sawsall will fix anything
