Results 1 to 6 of 6
    Default Door jamb Spring
    Does anyone know what this spring is called? I was getting off the floor and caught my pants on the spring and it broke off and I cannot find the part anywhere. When I search the Internet for door jam spring the only thing that comes up are the spring switches that are mounted at the forward portion and control the dome light.
Size:  61.8 KBName:  42AF312E-56C7-4367-B9A5-14E0B8A2A527.jpeg
    FEP Senior Member fascat's Avatar
    Greensburg, PA
    I'm not sure of the correct name for that but I believe it is for the seat belt retractor.
    Unfortunately that part is attached to the seat belt retractor mechanism by a cable and I don't believe any of that is replaceable with the exception of the plastic bezel that holds the plunger in place on the door jamb. You will have to find a good used seat belt with a good plunger to replace the whole assembly. The only other option I am aware of would be to push it back inside the door jamb and then plug the hole with a rubber grommet.
    If you need the plastic bezel that is available aftermarket now here" https://lmr.com/item/LRS-7989SBB/Mus...er-Bezel-79-89
    I like the way you think Trey. I’m gonna push it down and cover it with a grommet.
    Jul 2010
    Houston (Clear Lake), Texas
    ^^^...Yep, that's what I did too...
    HAD
    HAVE
    Similar thing happened to mine last fall in the driver’s side. :-(
    Seat belts don’t retract correctly now when door opens. I have to give it little yank to get it retract.
    1985 Mustang GT convertible triple white
    Stock survivor
