Results 1 to 6 of 6
    Default Dual exhaust on 85 Tbird
    I want to install dual exhaust on my 85 Tbird 5.0. I have factory Mustang headers and h-pipe. How much of a headache am I looking at and will tailpipes from 85-86 mustang style work? Thank you for any tips/ suggestions
    Ray.
    You’ll need a double hump transmission crossmember, and if the floor pan is longer than a mustang then you’ll need flow tubes to the mufflers longer than a mustang. Hopefully it has a single fuel pump, if it has the 2 pump system then you’ll need to convert it to a single in tank pump and get rid of the rail pump/filter (sits in the area that the passenger muffler goes). If it has a 7.5 rear axle then you’ll also need to relocate the brake lines from the body to the axle since that brake line/hose is in the location of the passenger tail pipe. For the tailpipes I would look into Stinger Performance, they have a tailpipe kit for Fairmonts/Thunderbirds that should fit (will probably need hangers added for the dual pipes). So in summary it could be easy or it can be rather involved to go with dual exhaust and tails.
    FEP Power Member 86-TC/SVO's Avatar
    Aug 2010
    Connellsville, Pa
    It was easy on my 86 TC for lack of duals coming from the engine (down pipe to converter and a y pipe to duals). All I needed to do was re-locate my fuel filter for the other muffler.
    86' SVO 1C # 17 of 3379 86's #6475 of 9837
    86' SVO 1C #497 of 3379 86's #6955 of 9837
    84' GT Turbo #4 of 3241 GT Turbo HB's #560 of 3935
    87' Thunderbird TC 1 of 10
    http://www.foureyedpride.com/content...e-of-the-Month
    Jan 2004
    Olathe, Kansas
    I suspect 85=CFI and that = 2 fuel pumps. Back in the day (80's), I had a shop run duals on my 85 V8 cougar. Was a $100.
    Now stang-less.
    88 Cougar 5.0
    Jan 2004
    Olathe, Kansas
    This is true!
    Now stang-less.
    88 Cougar 5.0
