Recently purchased a Mongose M15 touch-key automatic dual circuit immobiliser and are now going thru the process to install.
Have all the wiring diagrams downloaded from here + Haynes Repair Manual Diagrames to suit, what I don't have is the knowledge of which wires I should connect to and where I should be looking to find them. Being a dual circuit, I can immobilise two componets.
The Maximum continuous rating of this product is 10amps per circuit, so at a guess, I would say that would illiminate the Starter, leaving spark and fuel.
For spark I have located a Red + Light Green wire to be common to the Coil and Distributer which appears to pass thru the firewall. Please correct me if I am wrong.
For the Fuel Pump, my guess is, I should be looking for the power wire to the Fuel Pump Relay and I do not know where to find the Fuel Pump Relay and unsure what colour wire I should be looking for. Assistance required here.
Ignition Input - requires connection to the ignition wire of the vehicle which has +12V on both the "Ignition On" and "Crank" switch positions, so from that, guessing it would have power whilst the car is running. My guess is I should be looking for this wire from the Ignition switch at the Steering Column and again do not know which colour.
Also require to connect to a +12V power wire, and again, do not know which colour wire is best or where to locate.
Any help here will be most appreciated, Thanks in advance.
M15OPGUIDE.pdf
Also attached 2 x wiring diagrams, one sourced from 4 eyed and another in colour from google searching.
86_Mustang-ECC-EFI.pdf86_Mustang_Engine_Compartment.pdf
